• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    Free Edges and Non Manifold Edges Results in Midplane Model.
    266 Views, 2 Replies
    08-27-2012 12:29 PM
    Hi!
    I have a problem meshing a model of Basket in Midplane. The following images show the results of Free Edges and Non-Manifold Edges, throw by the diagnostic tool of the program. I can´t understand this results. What steps should I take if these results are a problem?. The piece have a max thickness of 5 mm, localized in the ribs.
    I know that, for midplane, Free Edges and Non-Manifold Edges can be different of 0.
    Any advice is welcome and appreciated.
    Thanks for Help!
    Mata.
    Please use plain text.
    Valued Contributor
    PascalGosset
    Re: Free Edges and Non Manifold Edges Results in Midplane Model.
    09-07-2012 06:33 AM in reply to: edguy2112
    You didn't do anything wrong. It's a trouble of Midplane.
    The only way is to correct manually the mesh errors.
    As your part is symetric, you can work on a quarter and copy it once the corrections done.
    "Maybe Moldflow does not work properly, but the real world neither."
    09-08-2012 11:08 AM in reply to: edguy2112
    Ok, thank you very much. I am alredy solving problems manually.
    Regards.
    Mata.
