- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear Moldflow Users,
I am doing moldflow simulation on clutch master cylinder body which is of Technyl A218 V30 material.It is a cylindrical component with 4-5mm thick, height around 150 mm, outer diameter will have two flanges and inner diameter will vary along the height from 24 t0 15mm. Kindly imagine the part.
The objective of the project is to correlate the deformation (inner diameter) results of simulation with the real measurement.The simulation result shows much deaviation from the real measurement. This is because the measurement in real is taken in room temperature. But in moldflow simulation I have specified the cycle time as 50 sec. At the end of this cycle time the part has a temperature range of 70 to 130 deg C.
My doubt - Is it possible to bring the part to room temperature in the mold flow simulation.
In real, around 150 C the part get ejected and sourrounding air cools the part to room temperature.
We have to bring this effect inside moldflow simulation.
Process parameter
As in real
Mold temperature - 80 C
Injection temperature -295 C
Injection time - 0.81 Sec
Injection pressure - 894 bar
Packing time (profile)- 11 sec
Packing pressure (profile) - 500 bar
Assumed
coolant inlet temp - 65 C
cycle time - 50 sec
Thanks and Regards
Ramesh
