Autodesk Simulation Moldflow Insight
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
Clamp Force Security Coefficien t
- Highlight
- Email to a Friend
- Report Inappropriate Content
Hello everyone,
Is there any security coefficient for clamp force calculation inside moldflow, or should we muttiply with some number.
I have heard somewhere about multiply with 1.2 but i could not be sure.
Best regards.
Levent
Re: Clamp Force Security Coefficien t
- Highlight
- Email to a Friend
Hello Levent,
I'd be glad to help with your inquiry, but I'm not familiar with what a "Security Coefficient" would be so could you please explain further? Are you referring to a Safety Factor that you might want to use when sizing an injection molding machine for your part?
- Highlight
- Email to a Friend
Dear Shawn,
Securty factor is the right term
I am doubting about clamp force. Moldflow calculated 1470 t, and machine capacity is 1500 t. Is this secure that using this machine, or should i multiply 1470 with 1.2 (security factor) like 1760 t and use different enj. machine?
- Highlight
- Email to a Friend
I commonly refer to this as a Safety Factor, but I now understand what you are looking for. We do not add a Security/Safety Factor in the clamp force calculations. The solver basically calculates the pressures and surface area in the XY plane and then multiplies the two to derive the clamp force prediction. It would be up to the engineer to size the machine based off of the clamp force predictions, but a general rule of thumb would be to not exceed 80% of the machines maximum clamp force. For example, you probably would not want to go higher than 80 ton on a 100 ton press. Some might push this limit a little further, but then you're not leaving yourself much of a window.
- Highlight
- Email to a Friend
Hi Karel Kapil,
nice to meet you again...
I agree with Shawn, Safety Factor could span within 80% up to 90% of the force of your machine. It depends just on how much you're confident with your model. Morevoer it depends also on the machine, an old machine probably has a worse control on clamping force respect to a bran new one.
