Cannot find Injection-Compression under Molding Processes
Hallo,
I want to run an injection compression analysis but cannot find the injection compression process at the Molding Prcess Setup. Also the Tools > Workspace > Customize Menue did no exist. Can you please help me!Using Moldflow Insight 2013
nordhb
the Injection Compression analysis is mesh dependent, and in ASMI 2013 it is available for mesh type Midplane.
Please, change to mesh type Midplane, and you should then be able to see molding process for Injection Compression Molding.
Berndt
Berndt Nordh
That's it!
Thanks for helping me!
