Autodesk Simulation Moldflow Adviser
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
CAE Data exchange
- Highlight
- Email to a Friend
Hallo,
reading the Autodesk Símulation Moldflow Compare Website http://usa.autodesk.com/adsk/servlet/pc/compare/in
Where is a documentation or tutorial available for that feature to transfer simlation results from moldflow to simulation multiphysics?
BR
Re: CAE Data exchange
- Highlight
- Email to a Friend
this is available in the in the wikihelp:
http://wikihelp.autodesk.com/Simulation_Mechanical
There is also an validation document:
Autodesk Moldflow Structural Alliance 2012
Validation Report: Additional Data Mapping to Structural Analysis Packages
which you can access from subscription center:
http://subscription.autodesk.com/
Hope this helps.
Berndt
Berndt Nordh
Moldflow Support Specialist
Product Support
Autodesk, Inc.
Re: CAE Data exchange (Moldflow/ Multiphysi cs)
- Highlight
- Email to a Friend
wikihelp describes at section Use Moldflow Results - Step 2: "For parts that correspond to the plastic part(s) to be analyzed in Moldflow, set the Element Definition: Material Model to Moldflow. This is an anisotropic material model."
Where is this selection?
Kind regards
Bernd
- Highlight
- Email to a Friend
regarding the analysis type in Autodesk Simulation Multiphysics.
The Moldflow element definition is available in Analysis type:
Linear or Non-linear
If you for example select Linear > Static Stress with Linear Material Model
and then enter Element Definition you will see the Material Model: Moldflow
Or if you for example select Nonlinear > MES with Nolinear Material Model
If you have further questions about using Autodesk Simulation Multiphysics,
please, post in forum http://forums.autodesk.com/t5/Autodesk-Simulation-
Berndt
Berndt Nordh
Product Support
Autodesk, Inc.
