Autodesk Simulation Moldflow Adviser
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
BASF Material Data
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I use TPU from BASF grade Elastollan C98 material for my application. Pl inform if material data for this material is available in the material data base i.e. in .udb file.
If not, How can I get this file? If I have to do measurements and then through your center get a .udb file, pl advice what all data is required?
Re: BASF Material Data
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Autodesk Moldflow Adviser 2013 SP2 does not have this material grade, Elastollan C 98, from what I can see.
The recommendation is to contact the material supplier to get an udb-file (material data file for analysis) of requested material.
If you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com
and they will provide documents where to enter raw data.
If all completed you will get measured data fitted and an udb-file for analysis in return.
You can also contact:
Autodesk Moldflow Plastics Labs
http://usa.autodesk.com/adsk/servlet/item?id=13151
and test the material as service.
Berndt
Berndt Nordh
Moldflow Support Specialist
Product Support
