• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Adviser
    New Member
    darken98
    AutoDesk Security Failure
    197 Views, 3 Replies
    12-05-2012 10:37 AM
    Hi just installed AutoDesk MoldFlow 2010-R2 on a Windows 7 64bit machine and when going to launch it I received the attached screen shot.
    I've got the correct license server, it's pingable, and the other users who are all on Windows XP 32bit are having no issues.
    I get the same error after installing Moldflow 2011.
    I've checked the license server manager, and it's pointing to the correct license.
    Any help would be awesome!
    Thanks!
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: AutoDesk Security Failure
    12-05-2012 02:49 PM in reply to: darken98
    For more information about Network License Manager connectivity issues and IPv6, please see my discussion post here:
    http://forums.autodesk.com/t5/Installation-Licensing/Network-License-Error-1-5-15-and-IPv6/td-p/2982...
    Moldflow licensing is a little different than other products, to my memory.  I have solved this problem for a customer in the past but failed to take down any notes on what I did.  I do know there is additional license configuration that needs to take place to make it work though.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
    New Member
    12-13-2012 06:40 AM in reply to: TravisNave
    i have the same problem as darken98.
    "Autodesk security failure"
    is there any solution to fix that problem?
    New Member
    12-26-2012 04:19 PM in reply to: kamel.achour
    Hi, have this problem ("Autodesk security failure") too... May be, something wrong with my russian version Windows 7 x64?
