• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Adviser
    New Member
    LoriModad3189
    Adding Material to the Material data base
    1028 Views, 4 Replies
    08-05-2010 12:27 PM
    I have two materials that I need to use for my moldflow but they are not listed in the Material Database.  How do I go about getting these listed?
    Please use plain text.
    Product Support
    Re: Adding Material to the Material data base
    08-06-2010 04:48 AM in reply to: LoriModad3189
    have you got the two materials as udb-files? (material data files for flow analysis)
    If, in Analysis Wizard, tab Material, you can Import udb-files for analysis.
    If you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com
    and get measured data fitted and a udb-file for analysis in return.
    Does this answer your question?
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    New Member
    LoriModad3189
    08-06-2010 05:14 AM in reply to: LoriModad3189
    Good Morning,
    Thank-you for your quick response. I do not have udb files.  Where do I get a udb file?
    Product Support
    08-06-2010 05:20 AM in reply to: LoriModad3189
    what you can do:
    - ask the material supplier for an udb-file
    - If you have measured data, raw data, of material you can contact datafittingmoldflow@autodesk.com
    and get measured data fitted and an udb-file for analysis in return.
    (material supplier might have measured data on this material?)
    Otherwise one have to look up an equivalent material in database.
    (Maybe material supplier can suggest an equivalent that can be used)
    Berndt
    Berndt Nordh
    Product Support
    New Member
    12-17-2012 11:14 AM in reply to: LoriModad3189
    I have a .udb data base for a material I commonly use that isn't in the library.  How do I add this material information.  I attempted to import the file with Analysis izard, but the material doesn't show up in my library list.
