• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Moldflow Adviser
    New Member
    Activation Moldflow Adviser
    216 Views, 2 Replies
    04-04-2012 11:52 AM
    I have installed the Autodesk MoldFlow Adviser 2012 for Student Version.
    When I want to activate the product, I got a "license.lic" file and I must take it into License Manager Folder in Program Files>Autodesk>Licencse Manager. But there is no folder like that in my program files.
    I have a few days to activate it. Is there any other way to activate this Moldflow Adviser?
    Thank you.
    Please use plain text.
    Product Support
    Re: Activation Moldflow Adviser
    04-05-2012 12:20 AM in reply to: jemiey
    the default license folder is normally:
    C:\Program Files\Autodesk Network License Manager\License
    or
    C:\Program Files (x86)\Autodesk Network License Manager\License
    If still having issues, for student support please raise issue at:
    http://students.autodesk.com , Click Support
    or use: http://students.autodesk.com/?nd=problem_form
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    TravisNave
    04-05-2012 12:00 PM in reply to: jemiey
    The term *activate* is generally reserved for stand-alone installations.  If your install is asking for product activation, then you have installed incorrectly.  Make sure in your installation options, you choose network version and point to the license manager.  You will need to set up your license manager and use the .lic provided.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
