• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Insight
    Member
    w18855
    About Warpage between non-filled and filled resin
    260 Views, 2 Replies
    11-18-2012 04:23 PM
    Hello
    My understanding is that glass filled resin may cause more warpage because of the anisotropy shrinkage. Especially more than 30% filled. I wonder if Moldflow simulation really counts on this or just use shrinkage rate.
    I don't really see the big difference in warpage between non-filled and filled resin during moldflow simulation.
    Please correct me!
    Thank you,
    Jung
    Please use plain text.
    Valued Contributor
    Re: About Warpage between non-filled and filled resin
    11-18-2012 07:04 PM in reply to: w18855
    Have you switched fiber orientation calculations On?
    Warpage calculations for fiber filled materials does not have much use when fiber is switched off
    Active Member
    01-03-2013 12:12 AM in reply to: w18855
    Hi Jung,
    Can you post some images regarding ther same. How is the filling pattern, and what about the material properties for both filled and non filled materials
    Ashwin
