• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Moldflow Insight
    New Member
    API macro, disposing synergy
    155 Views, 1 Replies
    02-15-2013 06:01 AM
    I've realized a VBS automation script using your  Moldflow API's and everything works correctly.
    My only question is:
    Is there any way to dispose correctly the Synergy interface?
    To be clear, using your example script is possible to run Synergy, but there is no any method to close it.
    http://wikihelp.autodesk.com/Simulation_Moldflow/enu/2013/Help/Insight/5756-Applicat5756/5778-Exampl...
    Running:
    cscript.exe //Nologo script.vbs
    The cscript termates correctly but the Synergy interface remains up.
    Can anybody help me?
    Simone Genovese
    Please use plain text.
    Product Support
    Re: API macro, disposing synergy
    04-05-2013 02:22 AM in reply to: genovese
    is a while since you posted this question, and maybe you already sorted it out.
    Anyway, there is a way. It is a bit harsh and terminates all synergy.exe processes, no prompts.
    Example:
    SetLocale("en-us")
    Set Synergy = CreateObject("synergy.Synergy")
    Synergy.SetUnits "METRIC"
    MsgBox "Done?"
    '** terminates all synergy.exe no prompt
    For Each objProcess In GetObject("winmgmts:").InstancesOf("Win32_Process")
         If objProcess.Name = "synergy.exe" Then objProcess.Terminate
    Next
    Wscript.Quit
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
