• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Moldflow Adviser
    piotr.wozniacki
    AMI Synergy, and AMA, on a laptop's external monitor
    249 Views, 6 Replies
    08-05-2011 12:11 PM
    Hi ALL,
    This is a very strange problem, and I'd be very grateful if you confirm or deny it: on my newest and greatest Dell Precision M6600 laptop with the Quadro 4000M graphics card, whenever I open AMA (or AMI Synergy) on the external monitor, I cannot open a study by clicking (or double-clicking, no matter how I have it set up in Preferences). The only way to open a study is
    - either to drag and drop a study into a window like this Forum webpage,
    -or by moving the entire GUI back to my laptop's own screen opening the project normally, and only then dragging the window back to the external monitor
    This is annoying when working on a project, but even more of a deal breaker during presentations!
    Just what the...?
    Piotr
    Please use plain text.
    piotr.wozniacki
    Re: AMI Synergy, and AMA, on a laptop's external monitor
    08-05-2011 12:57 PM in reply to: piotr.wozniacki
    I've just noticed that results cannot be displayed either - clicking just doesn't work in external displays!
    Product Support
    08-16-2011 12:50 AM in reply to: piotr.wozniacki
    assume latest graphics driver is installed.
    As Nvidia Quadro 4000M not available for test, this was tested on a laptop with Nvidia Quadro FX 770M, driver version 185.85.
    The cable connected from laptop to external screen directly, no docking station.
    After each graphics display change, restarted Moldflow Adviser 2012 and open project, study, display result.
    1- Single monitor
    Adviser interface works as expected - can open study and display results on external screen.
    It works to open study and display result, and in laptop screen display mode of using "External display only" and "LCD + External display".
    2- Dual monitors
    Changed display properties settings to "Extend my Windows desktop on to this monitor"
    Then in display properties settings moved screen 2, to be left of screen 1 : the behaviour you describe can be repeated.
    (Screen 1: still primary monitor)
    Solution: in display properties settings: screen 2, to be right of screen 1 (default setup)
    Start, or restart, Adviser after change of display properties settings
    This makes it work as expected.
    or
    run in Single monitor mode, not using "Extend my Windows desktop on to this monitor" and select
    "External display only" or "LCD + External display".
    Does this solve the issue for you?
    Berndt
    Berndt Nordh
    Moldflow Support Specialist
    Product Support
    piotr.wozniacki
    08-16-2011 01:20 AM in reply to: nordhb
    Thanks Bernt,
    It's good to know I'm not hallucinating :smileyhappy:
    Indeed, my observations so far are coherent with yours - as I usually work with 2 monitors (including the laptop's internal LCD), even though it so happens my external monitor is positioned to the left, I made it the Primary monitor and all is well.
    However, the problem becomes more complicated when using the Optimus technology, which enables the Precision laptop to drive 2 (or even 3) external monitors, in addition to its own display. Then, on a monitor that is connected to one of the digital outputs (DVI, HDMI, or DisplayPort), all 3D elements of the mesh (like Beams or Tetras) apper black - unless I move the Lighting slider fully to the left in Preferences, in which case 3D models aren't rendered legiblly. But this is probably the Optimus thing...
    Finally, even with a simple scenario of the internal display plus VGA projector, it can still be a problem. This is most often used at presentaitons, so of course I cannot make the projector screen my Primary desktop...
    Anyway: is it classified as a bug n AMA/Synergy, and will it be addressed in future updates/service packs?
    Piotr
    Product Support
    08-16-2011 02:43 AM in reply to: piotr.wozniacki
    the advice in this case is to have the VGA projector as screen 2.
    Using the default settings in display properties settings: screen 1 to the left, and primary for laptop and screen 2, to the right,
    the VGA projector will be screen 2.
    Then using "LCD + External display", and change display properties settings to "Extend my Windows desktop on to this monitor"
    Adviser interface works as expected - can open study and display results on external screen, the VGA projector.
    Berndt
    Berndt Nordh
    Product Support
    piotr.wozniacki
    08-21-2011 04:48 AM in reply to: nordhb
    Dear Berndt,
    Sorry for using this forum for communicating with you, but I have tried to send you a message via Siebel portal, and am unsure whether it reached you (a basic question re: Asset ID reuired at filing cases).
    Please come back to me on this matter; Regards
    Piotr
    Product Support
    08-21-2011 11:24 PM in reply to: piotr.wozniacki
    Hi Piotr,
    I have been notifed of your request.
    Berndt
    Berndt Nordh
    Product Support
