Autodesk Simulation Moldflow Insight
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
AMI Synergy, and AMA, on a laptop's external monitor
- Highlight
- Email to a Friend
Hi ALL,
This is a very strange problem, and I'd be very grateful if you confirm or
deny it: on my newest and greatest Dell Precision M6600 laptop with the Quadro
4000M graphics card, whenever I open AMA (or AMI Synergy) on the external
monitor, I cannot open a study by clicking (or double-clicking, no matter how I
have it set up in Preferences). The only way to open a study is
- either to drag and drop a study into a window like this Forum webpage,
-or by moving the entire GUI back to my laptop's own screen opening the
project normally, and only then dragging the window back to the external
monitor
This is annoying when working on a project, but even more of a deal breaker
during presentations!
Just what the...?
Piotr
Re: AMI Synergy, and AMA, on a laptop's external monitor
- Highlight
- Email to a Friend
I've just noticed that results cannot be displayed either - clicking just
doesn't work in external displays!
- Highlight
- Email to a Friend
Make sure you have the latest nVidia graphic drivers installed for your graphics card.
Using the external monitor in extend mode with AMI or AMA on the external monitor and opening a model by double clicking is a standard function.
Paul Larter
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Dear Paul,
Of course I do have the latest nVidia driver, and sure it's just an obvious method to open studies etc. on a secondary windows monitor, with desktop stretched. Yet, it simply doesn't work here.
FYI, the computer affected is the "latest and greatest" Dell Precision M6600, with the Quadro 4000M graphics. A somewhat special thing about it is the nVidia Optimus technology, allowing use of both the graphic accelerator (Quadro in this case), and the Intel HD graphics integrated with the 2nd generation i7 processors (Sandy Bridge).
My guess is that this technology being still quite new and unmatured, the mouse input is somehow lost with certain operations when an external monitor is connected - however, and this is the only reason I posted it here, all other graphics application I'm using (like the entire Autodesk Design Suite -- including Inventor, 3D Studio, Showcase, etc.) work perfectly well on the configuration. So, there must be something specific about both Moldflow apps (AMA and Synergy) that is not fully supported on this specific platform... BTw, I'm also having problems when the graphic window is split into 4 views: the performance drops dramatically when rotating the model, and black (empty) areas appear very often as if the background wasn't properly refreshed.
On the other hand I realize this is more a computer manufacturer - related issue; just wanted to hear of other 2012 software user's experience. Cheers
Piotr
- Highlight
- Email to a Friend
Another thing to try is to turn off the three 'Fade' options under the Performance - Visual effect menu in Windows.
This can be found by right clicking your computer name in the Start menu - Properties - Advanced System Settings to bring up your System Properties, choose the Advanced tab and then click Settings under Performance.
In the list untick the 3 'Fade' options.
Paul Larter
Support Specialist
Product Support
Autodesk, Inc.
- Highlight
- Email to a Friend
Hi Paul,
To my amazement, unticking the "Fade" options helped - now I can load projects/results by clicking, just as with my laptop's internal monitor. I also seem to have much less redrawing artifacts... So, presentations using a VGA projector will be fine - thanks a lot for this tip!
However, upon further examination I must say that on my Dell Precision M6600's digital monitor ouputs (DVI in my case) nothing has changed, fortunately:
- the left pane items (projects and results) do not load at a mouse click (they can only be opened by dragging)
- 3D elements (tetras and beams) display black, unless I drag the "Light Shading" slider full left in Preferences (but in this position, 3D views become much less legible).
So, looks like nVidia must still do some homework on their newest mobile Quadro cards...
- Highlight
- Email to a Friend
Dear all,
i've got just the same problems as described below, but changing the display settings in Windows (Fade options) didn't help.
I'm working on a brand new Workstation with a NVIDIA Quadro 5000 with latest drivers installed and Windows 7 64bit SP1.
Also on my old Workstation I had problems with synergy since AMI 2012 (artifacts, missing result plots, black areas in the results ...). but there I had only one monitor.
For me it seems to be a problem of AMI 2012
Hope we'll find a solution for it !
Greetings
Marco
