• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Moldflow Adviser
    New Member
    jungjohann
    3D mold file needed
    640 Views, 2 Replies
    11-19-2010 08:11 AM
    Our compnay, Flow Polymers currently makes an additive for the plastics industry which increases flow, decreases pressure need in a mold and compatibilizes dis-simlar resins.  We have done numerous field trials and now need to prove empirically what our product does,  I have had our additive compounded and characterized and will do a mold flow analysis to prove our claims.  My problem is obtainng a 3d Part file that's appropriate to do the mold flow.  I am looking for a larger part and will be measuring temperature, pressure and time.
    If anyone has an idea on how to obtain a 3d Part file would you contact me at jjungjohann@flowpolymers.com
    Please use plain text.
    Member
    artflow123
    Re: 3D mold file needed
    11-19-2010 08:50 AM in reply to: jungjohann
    Sorry can you explain a bit better?
    What are you looking for? a 3d part (any part) or a complete 3d mould?
    regards
    New Member
    jungjohann
    11-19-2010 08:54 AM in reply to: artflow123
    In order to do a mold flow analysis, I was told I needed to supply the compnay with a 3D part file  so that they could use that as the base to test the materail.  I'm not sure what all is involved or included in a 3D part file but I imagine its not a file of the mold but of the actual part, including dimentsions etc
