Autodesk Simulation Mechanical and Multiphysics
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
beam deflection error
- Highlight
- Email to a Friend
today i have been having problems getting the correct deflection on a simple Universal column (203UC46.3).
The stresses are spot on at 8.3 MPa in the middle of the beam. I have applied a UDL of 840.3 N/m. The beam is 5.95 m long.
I have midplane meshed this. The deflection however is wrong at 1 481 327 mm! It is about 1 million times too much. Hand calcs give 1.5 mm.
I have made sure my model units = my display units as I had a problem earlier this week with shrink fits.
Has anyone got some insight on this?
Hi Tim, I opened up your fem file, set the plate thickn...
- Highlight
- Email to a Friend
Hi Tim,
I opened up your fem file, set the plate thickness to be the midplane mesh thickness and material as Steel(ASTM-A36). I ran the analysis and got the maximum deflection as 1.5mm (which is what you expected). In short, I did not find any problems with your settings(unless you specified too thin a thickness or too weak a material). What version of the software are you using?
Perhaps you might want to update to service pack 2
Regards
Ilyas
Re: beam deflection error
- Highlight
- Email to a Friend
I spotted the error thanks to your tip. I used the default alloy steel as a quick check. It has a youngs modulus of 0.205 N/mm^2. It should be a million times bigger, hence my million times error! This should be changed by you guys especially because its a default!
I'm using sp2 by the way.
Deflections are now correct. Thanks! By the way, If I select "use mid plane mesh thickness" does this pick up the different thickness in the web and the flange?
- Highlight
- Email to a Friend
Yes, the Use mid-plane mesh thickness picks up the different thicknesses of plates provided that they are different surfaces. One surface can only have one thickness.
Regards
Ilyas
- Highlight
- Email to a Friend
Either my memory or the Help documentation is wrong. But I thought the midplane mesh actually used the calculated thickness for each element, not just the same thickness for all elements on the same surface. So if you had a rolled beam where the flange thickness changed, you would see that "taper" by the varying thickness in each element. ("Results Contours > Other Results > Element Properties > Thickness of plate" in the Results enviornment.) Of course, the change in thickness would be a step change from element to element, not a smooth change.
This capability, if it exists, may be different for linear stress, MES, and thermal.
Mechanical Engineer
Pittsburgh, PA
15 years experience with Simulation Mechanical
- Highlight
- Email to a Friend
Thanks both of you for your info. I've been on a good learing curve with ASM these last few weeks. I've just installed sp2 on my home machine. I'm now trying to mesh a much larger group of assembled beams. I'm getting quite consistent crashes where the Autodesk error report comes up, sends a report and then it continues to mesh the model.
Has anyone seen this error?
Regards
