• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    ccz90
    Why pin joint (truss element) collapsed?
    196 Views, 2 Replies
    09-10-2012 06:54 AM
    I use pin joint setting in my numerical model. But the solver program always shows lots of warning messages like:
    *** Warning : Truss element collapsed!
                          Numerical exception may occur
                          Element number=51
                          Original element length =11.87
                          Current element length=NaN
     then the time step is reduced again and again, and the model seems difficult to converge.
    Why and how to avoid the problems? Thanks!
        CCZ90
    Please use plain text.
    Distinguished Contributor
    Re: Why pin joint (truss element) collapsed?
    09-10-2012 10:02 AM in reply to: ccz90
    It sounds like a numerical problem in the MES simulation, so I suggest trying a smaller time step just before this event occurs. (online wiki Help) I am hoping that a different calculation path will avoid the problem. (NaN stands for "Not a Number", so something is occurring mathematically.)
    Otherwise,
    1. What material model are you using for the trusses?
    2. What is the stiffness of the trusses? (Cross-sectional area and modulus of elasticity)
    3. What step does this occur on?
    4. What is the force in the truss before it collapses? ("Results Contours > Other Results > Element Forces > Axial Force")
    5. What element type is the truss connected to?
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    15 years experience with Simulation Mechanical
    ccz90
    10-03-2012 09:00 AM in reply to: AstroJohnPE
    • What material model are you using for the trusses?
          Linear
    • What is the stiffness of the trusses? (Cross-sectional area and modulus of elasticity)
          Cross-sectional area from 7~300 mm^2 , E= the defacut material parameters from autodesk material library
    • What step does this occur on?
          Changeful. It maybe at the bigining or the process of the calculation.
    • What is the force in the truss before it collapses? ("Results Contours > Other Results > Element Forces > Axial Force")
         In some cases, the forcees are very small, 7 ~ -4.9N
    • What element type is the truss connected to?
        Brick (isotropic elastic steel)
    I have used a smaller time step with bigining of 1~0.1 ms, and the solver might reduce the time step more. The
    warning messages still display  randomly.
        Ccz90
