Message 1 of 13
07:01 PM
- Mute
- Permalink
- Report
I'm trying to do a simulation of fatigue on a 737 airplane landing gear. I have it modeled, calculated its force in each axle, and ran the fatigue for the force applied within 0.2s The landing gear is not perfectly equal to the real one, but its close enough. After doing the simulation, i get 1 cycle endurance with 322000N on each axle, even with the normal aircraft weight (125000N) on each axle, the design fails. A plane most certainly doesn't break when its supported by its landing gear. I have basically a T modeled, with loads on the small ends. Ill add any files if requested
Also, just to be safe i tested with doubled dimensions, still break, with 263 MPa max von misses stress
