• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    Units Conversion - Convection Coefficient
    491 Views, 1 Replies
    03-15-2010 07:21 AM
    New user here.
    Is there a built-in unit conversion calculator in Algor?
    I am looking for a conversion of Convection Coefficient
    from in·lbf/(s·°F·in^2) Aglor nomenclature to BTU/(s·in^2F) SolidWorks nomenclature
    Well I walked away from the problem to take care of other business and when I came back I realized the denominator is the same so I simply need to convert in·lbf to Btu but it would be nice if there was a simple conversion calculator built into Algor. If it is there, I haven't found it. Edited by: JDMather on Mar 15, 2010 5:22 PM
    Inventor Professional 2014 Edu 64-bit
    Please use plain text.
    Employee
    Re: Units Conversion - Convection Coefficient
    03-16-2010 05:35 AM in reply to: JDMather
    JDMather,
    Autodesk Algor Simulation 2010 provides the ability to change the model display and data entry to reflect any number of pre-defined "Display Units", made available in the top left of Algor's model tree. To learn more about this feature, access "HELP|Index" and type "Units".
    Pat Tessaro, P.E.
    Autodesk Inc.
    Pat Tessaro, P.E.
    Customer Support Engineer
    285 Kappa Drive
    Suite 250
    Pittsburgh, PA 15238
