• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    New Member
    Unable to apply material in a thermal study
    129 Views, 3 Replies
    11-21-2012 07:50 AM
    When I try to apply a material in a thermal study I get an error message similar to this and cannot  apply any material:
    Unexpected error
    Modification of a ****** thermal element, the isotropic/orthotropic has not been specified
    (*translated*, my version is in french...     (sim mechanical 2013))
    No matter what type of element I used, or what type of material model (iso, ortho, iso temp dependent...) I apply in the element definition I always get the same error. Even in a blank study with no geometry in it, when I create a component, select the element type and def,  and try to apply a material I get this message error. This only happens in thermal studies, first time trying to use thermal studies...
    Seems like the software cannot read the material model from the element definition. I tried reinstalling the software and still get the same message.
    Please use plain text.
    Distinguished Contributor
    Re: Unable to apply material in a thermal study
    11-21-2012 08:31 AM in reply to: Magre
    Hi Magre,
    I agree with your thought: sounds like the software is not able to read the element definition. What happens if you do this test?
    1. Define the element type to be brick.
    2. Edit the Element Definition and set the material model to Orthotropic.
    3. Click OK to close the Element Definition.
    4. Edit the Element Definition again. Is the material model set to Ortho?
    If it is Isotropic -- the default -- this would support the idea that the software is not able to read the Element Definition. In this case, try saving the model to another folder where you have successfully worked on other models, or save it to a really short folder and filename, such as C:\junk\test.fem. (Everyone needs a junk folder, right?)
    Also, I see that you have version 2013. Have you installed service pack 1 and/or 2? I do not recall any problems like this that the service pack would have fixed.
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    15 years experience with Simulation Mechanical
    New Member
    11-21-2012 08:47 AM in reply to: AstroJohnPE
    Turns out SP2 was not installed, which I tought was the case. Everything seems ok now.
    New Member
    03-29-2013 05:12 AM in reply to: AstroJohnPE
    Hi, i have the problem with my installation.
    My study i steady state heat transfer.
    When i edit material, the library give me an message that the material is not isotrop.
    Would you like to help me.
