• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    Active Member
    Tracker2012
    Track meshing
    98 Views, 4 Replies
    07-12-2012 02:24 PM
    I am trying to optimize a sprocket drive but need help simulating the rubber belts holding the drive section together.
    Any ideas?
    Have access to Several autodesk products. I was able to get a short simulation in Inventor but i need a more accurate one.
    I have attached a pdf file showing the basic idea.
    Please use plain text.
    Active Member
    Tracker2012
    Re: Track meshing
    07-13-2012 08:26 AM in reply to: Tracker2012
    i know have a full loop assembly with a drive sprocket and two wheels. The fist run it ran but the belts start to bunch up. So i put a spring between the two wheels and it shows some movement put seems to bind up and stop moving. If any one thanks they can help i can send them the files.
    Distinguished Contributor
    madg1
    Re: Track meshing
    07-13-2012 08:43 AM in reply to: Tracker2012
    i guess you are in wrong forum....
    madg1
    ASIMM 2012
    Active Member
    Tracker2012
    Re: Track meshing
    07-13-2012 08:52 AM in reply to: madg1
    I am wondering if i could or should try this in Autodesk algor Simulation?
    madg1
    Re: Track meshing
    07-13-2012 10:19 AM in reply to: Tracker2012
    then  rubber belts  and motion goes non linear....which needs some expert advice...:smileytongue:
    madg1
    ASIMM 2012
