• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    Surfaces will not contact...
    419 Views, 7 Replies
    01-29-2013 10:23 AM
    The surfaces in my model will not contact. I have tried selecting just the two faces, the whole parts, etc. I have done linear, nonlinear, and MES... I have no idea why they keeps passing through each other.
    Please use plain text.
    Employee
    zhuangs
    Re: Surfaces will not contact...
    01-29-2013 11:36 AM in reply to: isaacc
    You might upload the model for us to easilly investige it.
    -Shoubing
    01-29-2013 11:50 AM in reply to: zhuangs
    Ok I will as soon as I get a chance! Could it be because the part is not actually touching, just exaggerated to touch?
    Employee
    zhuangs
    02-05-2013 12:15 PM in reply to: isaacc
    It seems that the contact is not detected.  I am wondering whether the contact is well set up between the surface really in contact.
    -Shoubing
    Member
    02-16-2013 09:30 AM in reply to: isaacc
    I have the same problem.
    I'm working on a FEA of a climbing carabiner (oval-shaped; one side of the oval is a gate which opens and closes allowing a rope into the carabiner).
    The gate of the 'biner has a hook which attaches to the "nose" of mainbody/biner.  However, this hook does not engage until the biner slightly deforms.
    I've attempted to use the separation/no sliding contact option, but the solver behaves as if there is no contact occuring.  The nose simply passes right through the gate hook.
    The initial gap of the system is about 0.040".  That means the nose must deflect 0.040" before the contact surface comes into play.
    Any help would be greatly appreciated!
    Distinguished Contributor
    02-16-2013 12:47 PM in reply to: charsguo
    Hi charsguo and isaacc,
    I suggest that both of you create an archive of the models and attach them to the reply. It would make it much easier to find the probem.
    See this thread for instructions on archiving.
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    15 years experience with Simulation Mechanical
    02-17-2013 03:34 PM in reply to: AstroJohnPE
    In Charlie's case, the analysis type was set to linear static stress. Contact only works in this analysis type when the gap/interference is 0. If the initial gaps are not critical to the design, I suggest that you remove them from the CAD model and start the process again. If the gap is critical to the design, then you must use an analysis type of "Nonlinear > MES". MES is the only analysis type that can handle surface contact between two surface with a gap.
    For more information, see the page "Types of Contact" in the wikihelp. I will try to submit an update to the page to help make it clearer that contact requires a 0 gap in most situations.
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    Member
    02-21-2013 05:34 AM in reply to: AstroJohnPE
    John,
    This fixed my problem.  Many thanks!
