• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    Active Contributor
    drpalo
    Surface contact, single part analysis?
    202 Views, 2 Replies
    04-18-2011 07:52 AM
    Good morning all,
    Can a part have surface contact with itself? For example, a structure imported as a solid CAD model that buckles onto itself but does not penetrate itself?
    Thanks.
    Please use plain text.
    Employee xli
    Employee
    Re: Surface contact, single part analysis?
    04-18-2011 08:24 AM in reply to: drpalo
    If you are making a MES model, make the surfaces of contacted portion not exactly matched, then in MES surface contact UI you would be ale to define the contact pair of same part/surfaces.
    If you use LSS, you probably also have to make the contact portion slightly seperated and then manually define some gap elements there to simulation the contact.
    -xli
    Employee
    zhuangs
    04-20-2011 12:43 PM in reply to: drpalo
    If MES is used, in the general surface-to-surface panel, you can define the contact pair:
    (1) if you know the two surface ID (such as 1, 2) of the surfaces in the same part, you can define the contact pair as
    Part/surface 1 with part/surface 2
    (2) otherwise, set part with part
