• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    Active Contributor tim
    Active Contributor
    Shrink Fit in Simulation Mechanical
    280 Views, 5 Replies
    10-10-2012 12:37 AM
    Greetings,
    1. I've been trying to do a shrink fit between a simple cylindrical hub and a round shaft (using ASM).
    2. I've been using solid brick elements for both parts.
    3. I draw the parts assembled in inventor with 0.15 mm radial interference
    4. I import into ASM
    5. I mesh with 8 node bricks
    6. I change bonded contact to shrink fit/no sliding
    7. I enter radial interference as 0.15 mm
    8. I solve with either sparse solver or automatic
    9. I get the message 'not tied down properly'
    10. The solution will not finish
    I've spent quite a while on this.  Could someone please give some suggestions on shrink fits?  I've used Inventor for this without a problem!
    Please use plain text.
    Employee
    Sualp.Ozel
    Re: Shrink Fit in Simulation Mechanical
    10-10-2012 08:41 AM in reply to: tim
    Did you apply any boundary condition / constraint to your model?
    Looks like that’s what you are missing for your setup
    Best Regards
    Sualp Ozel, PE
    Product Manager
    Digital Simulation
    Autodesk, Inc.
    Active Contributor
    10-10-2012 06:29 PM in reply to: tim
    Hi and thanks for replying.
    Yes, I've used a BC.  I've tried all sorts on fact.
    Since I posted this, I'm getting a result but not a correct one.
    -Hub is a simple Hollow cylinder, OD = 216mm, ID = 139.85 mm with 135 mm axial length
    -Shaft is solid and is 140 OD by 300 long with keyway
    -Static Linear Stress Analysis
    Contact Settings:
    -0.075mm radial interference
    -friction set to 0.25
    -Surface contact direction = normal to first part/surface
    -Direction Tolerance Angle = 10
    -Shrink Fit / Sliding
    Analysis Parameters:
    -sparse solver
    -iteration - mixed
    -200 iterations
    -stabilization Global/initial
    -stiffness reduction attempts 2
    Mesh on Both Parts
    -4 mm tets, 2nd order Or 6mm bricks
    Results Hub
    Radial Stress at ID = -550 N/mm^2 (should be -62 N/mm^2)
    Radial Stress at Od =0 (Ok)
    Axial Stress at ID = 1550 N/mm^2 (should be 152 N/mm^2)
    Results Shaft
    Radial Stress at Od = -650 N/mm^2 (Should be -62 N/mm^2)
    Axial Stress at ID = -350 N/mm^2 (should be -62 N/mm^2)
    The results are close to 10 x too high.
    Your thoughts
    Employee
    Sualp.Ozel
    10-11-2012 07:15 AM in reply to: tim
    I created the same setup using Inventor and ASIM-Mech 2013. the only difference in my design was the contact type. I used Shrink fit without sliding so that the model becomes stable. also using this contact type i was able to compare the results i get from Asim-Mech to Inventor-Sim. I am attaching my results images. You will see that with this setup the results for both software are very similar. I will also try to attach the Inventor part/assembly files along with the ASIIM-Mech Archive file to this post. Hope this helps
    Sualp
    Active Contributor
    10-11-2012 07:02 PM in reply to: Sualp.Ozel
    Sualp,
    thanks for this.  Could you please send the ach file.  I'm mainly interested in the radial contact pressure
    Regards
    Employee
    Sualp.Ozel
    10-12-2012 05:57 AM in reply to: tim
    Due to its size, I cannot seem to attach the archive to the forum. If you can e-mail me your contact information, I will be happy to send it to you directly. -Sualp sualp.ozel@autodesk.com
