• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    Active Member
    B_A_T
    Radial Offset for Beams
    461 Views, 3 Replies
    07-26-2011 07:59 AM
    I am trying to put a radial offset on a bunch of beams and was curious if there is a way to do it? Basically I want the location of the beams to be further out radially than I have them drawn. I have tried using a center node but since I need to enter an I and J node, it would seem I would need to define these nodes all the way around the circle to get an accurate offset. Is this the case or is there some way I am missing?
    Thank you in advance!
    Please use plain text.
    New Member
    guozh
    Re: Radial Offset for Beams
    08-17-2011 01:41 AM in reply to: B_A_T
    Beam offset is used to define the offset of neutral axis. The offset values DX, DY and DZ for I and J node are supposed to be in global coordinate system.  Moreover, I think there is no local coordinate system support for beam offsets.  If you were trying to offset beams using any local coordinate system, it would not be feasible.
    The best way is to redraw the lines (geometry model).
    Valued Contributor
    12-18-2012 08:18 AM in reply to: B_A_T
    I would really benifit by being able to do this also.
    For example. I have a round tank with a rim angle, I'd like to offset those beam elements radialy to properly represent the actual geometry.
    Distinguished Contributor
    madg1
    12-19-2012 07:00 AM in reply to: B_A_T
    this is one serious drawback, ASIM people should address.
    One workaround suggested by astrojohn was to use beam elements with high stiffness values to represent beamoffsets.I modeled a whole lattice structure using the above method.
    madg1
    ASIMM 2012
