• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    New Member
    Pin Mass Density
    82 Views, 2 Replies
    12-10-2012 08:11 AM
    Hi there
    We knewd that in Algor we simulate the joints or pin by Truss element.
    My question is if I creat a pin by the truss elements
    What the mass density of truss use for?
    Please use plain text.
    New Member
    Re: Pin Mass Density
    12-10-2012 07:07 PM in reply to: s903905
    II fouond that the mass of pin(created by truss element) has the relation with section area and the number of truss.
    So what is the exact definition of mass density of the pin?
    Distinguished Contributor
    12-10-2012 07:51 PM in reply to: s903905
    Hi s903905,
    I am not entirely clear what you are asking or the reason you are asking. Just like any part, the mass equals (the volume of the elements) times (the mass density). For of a part made from truss elements, the mass equals (the total length of all elements x cross-section area) times (the mass density). If performing a modal analysis, the mass affects the frequency. If performing a linear stress analysis and gravity is applied, the weight causes a load. And so on.
    If you do not want the pin to have any mass, then set the mass density to 0.
    Let us know if you have any other questions.
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    15 years experience with Simulation Mechanical
