Autodesk Simulation Mechanical and Multiphysics
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Re: Phantom Displaceme nt Constraint s
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
K-nodes are fully constrained.
To check them, select a beam element, right-click and pick up "Beam Orientations", you should see the following picture.
"Use Default" means code generates them at far away places. Otherwise, you should see the coordinates there.
If this response answers your concern, please mark it as "solved".
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Another way to try:
Can you temporarily disable/surpress the other parts and only keep the problematic part? Try add some loads and boundary conditions on it and see whether the phantom displacment constraint still exist?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Actually, I am not sure that you clearly indicated where these "phantom constraints" appear in your model. From looking at your original screenshot, most of us probably assumed the item you were talking about is the circle just underneath the arrow at the top of the image. That's what I assumed.
By enlarging the image, I noticed that the circle is orange, not red. Orange circles are beam end releases. I assume that the location coincides with the location where you applied end releases in the FEA Editor. Note that the symbol appears part way between the two nodes on the beam.
John Holtz, P.E.
Senior User Experience Designer, Simulation
Current version of Mechanical & Multiphysics: 2013 SP1 (2013.01.00.0012 28-Jun-2012)
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Sorry to throw you off with the beam end release. I don't know where the phantom constraints are as they do not show up in the model anywhere. I spoke to Pat Tessaro this morning - he has the model and is checking through the database to determine what is really happening. I will be sure and let all know what he finds out. Thanks for all your input.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
The model had some very poorly shaped elements that were created due to the presence of construction points. The poorly shaped elements resulted in a large variance of stiffness and an ill-conditioned matrix. The only clue was a warning message that the stiffness ratio exceeded a predetermined warning value.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks for your update.
