• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    Valued Contributor
    scudelari
    One direction translation constraint
    81 Views, 1 Replies
    09-11-2012 07:09 AM
    Hello Everyone,
    The question is fairly simple:
    1- Is it possible to create a constraint in Non-Linear Analysis so that a node would not be able to displace in one sense of, lets say, X, but to be allowed to displace towards the other sense?
    Thanks for the reply!
    Please use plain text.
    Distinguished Contributor
    Re: One direction translation constraint
    09-11-2012 08:42 AM in reply to: scudelari
    Hi scudelari,
    You would need to use some type of contact to accomplish that type of "constraint". Which option you choose depends on the particulars of the model, but the ones that come to mind are the following:
    • One of the contact elements (Contact, Coupling, or General contact elements)
    • Surface-to-surface contact
    • Impact plane.
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    15 years experience with Simulation Mechanical
