Autodesk Simulation Mechanical and Multiphysics
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Nonlinear elastic materials
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
I plan to perform analyses for 'nonlinear elastic materials' (that are not rubber and/or elastomer) by using Autodesk Simulation 2013.
How to analyze nonlinear elastic materials by using stress-strain curves and Poisson's ration in MES analysis? Is it possible for such analysis?
Best regards,
Akihiro Matsuda
Re: Nonlinear elastic materials
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Akihiro,
Yes, you can do with Autodesk Simulation Mechanical 2013.
If you have strain/stress curve of your elastic material, you can use curve-fitting function of hyperelastic or hyperfoam materials. This will estimate the coefficients of strain energy density function according to hyperelastic material model you choose.
If you just have Young's Modulus and Poisson's ratio, then Neohooken is the good starting point to try.
Good Luck!
Jaesung
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi Jaesung,
Thanks quick reply! I found some other FEM softwares that have 'nonlinear elastic model'. These software's 'nonlinear elastic model' use both 'Stress-Strain curve' and poisson's ratio, without using strain energy density functions.
Anyway, I will try to solve my problem by using your recommendation scheme.
Thanks again!
Akihiro.
