• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    Active Member
    mikebscott
    Net electric force on a part
    74 Views, 1 Replies
    04-06-2012 02:03 PM
    I am modelling a MEMS comb drive, and was looking to find the net electric force on one of the combs.  I made a simple model, as my model was too large to attach (even after compression, archiving, and zipping).  In this model, I am looking to find the net electric force (magnitude and direction) on the part named "Oscillator Comb".  Is there a method to do this?
    Thanks for your help,
    Mike
    Model is attached, in a zip folder.
    Please use plain text.
    Employee
    Re: Net electric force on a part
    04-09-2012 02:32 PM in reply to: mikebscott
    Hi Mike,
    It's very easy! In the Results environment, you want to display "Results Contours > Electrostatic Force > Vector Plot".
    Then select the nodes where you want to sum the forces, right-click, "Inquire Results".
    On the dialog, set the summary drop-down to "Sum", and the adjacent field will show the sum of each vector component.
    Sincerely,
    John Holtz, P.E.
    Senior User Experience Designer, Simulation
    Current version of Mechanical & Multiphysics: 2013 SP1 (2013.01.00.0012 28-Jun-2012)
