• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    Contributor nav
    nav
    Mesh Refinement - Odd Mesh Contact Points
    190 Views, 4 Replies
    03-30-2012 10:03 AM
    I've included the picture of the issue I've been having; basically I mesh the model, set refinement points and after doing so, the mesh shows up, in some areas, as shown in the picture.
    Any reason that this happens?  Having to go back and redraw the mesh by hand and solid mesh is overly time consuming.
    Thanks in advance for any and all help.
    Please use plain text.
    Distinguished Contributor
    madg1
    Re: Mesh Refinement - Odd Mesh Contact Points
    03-30-2012 10:18 AM in reply to: nav
    hi I am not an expert
    but did you check the model?i mean CHECK and shrink it and see if you see real elemnts there.....
    madg1
    ASIMM 2012
    Contributor nav
    nav
    03-30-2012 11:10 AM in reply to: madg1
    Having seen this problem before, yes, these are real elements.
    Nonetheless, here is a picture of the area that has been shrunk.
    madg1
    03-30-2012 12:35 PM in reply to: nav
    if uploading you model is not an issue for you, I can give a try....:smileyhappy:
    madg1
    ASIMM 2012
    Contributor nav
    nav
    04-05-2012 07:50 AM in reply to: nav
    No help or suggestions from any Autodesk employees?
    I'm assuming this is happening due to the fact that midside nodes are turned on.  Rather than the mesh connecting nodes at the edge of the part, it appears that they skip the first row of nodes on the first elements and proceed to connect at the midside node locations instead,
