• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    New Member
    Measuring applied load for an object moving under displacement control.
    71 Views, 1 Replies
    10-01-2012 03:05 AM
    I have a situation where I am modelling one bar moving at a constant displacement rate, pushing against a bending object. I want to know what load is having to be applied to move the bar at it's constant rate. Is there some way to extract this value? I have been using the magnitude of the reaction force on the underside of the bending object, but I'm not sure if that is correct.
    Thanks for any help.
    Please use plain text.
    Employee
    Sualp.Ozel
    Re: Measuring applied load for an object moving under displacement control.
    10-10-2012 08:47 AM in reply to: ucfbmrc
    In the Results interface, change the result type to Reaction Forces.
    Select the surface (more specifically all the nodes on that surface) to which you have applied the surface prescribed displacement. Right click, inquire results, and change the operator to “Sum”.
    Best Regards
    Sualp Ozel, PE
    Product Manager
    Digital Simulation
