• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    Active Contributor
    klnkai
    Accepted Solution
    Locking and other disadvantages of solid elements
    284 Views, 5 Replies
    02-10-2012 07:14 AM
    I would like to compare a plate model with a solid model. In the description it is said that you should have three elements in thickness.
    Is that recommended for stress-states that are analysed through the thickness and you could also leave one element in thickness or does it have to do with locking?
    Do the elements in ASIM have any safety against locking?
    I mean you can increase the integration order, but there are several other methods one can find in literature, like reduced integration etc.
    Please use plain text.
    Contributor nav
    nav
    Re: Locking and other disadvantages of solid elements
    02-10-2012 04:10 PM in reply to: klnkai
    Look into the use of midside notes on the solid elements.
    Employee
    02-13-2012 05:01 AM in reply to: klnkai
    In ASIM MES, mean-dilatation, one kind of selective reduced integration method, is provided for brick and tetrahedron elements.
    Also, as mentioned, higher order elements are helpful, such as mid-side nodes.
    If this response answers your concern, please mark it as "solved".
    Active Contributor
    klnkai
    02-14-2012 08:35 AM in reply to: S.LI
    Okay, so the reduced integration is only available in MES?
    And what about these three elements in thickness? Are they only recommended to get a better result through the thickness or is there another reason related to locking or whatever?
    Employee
    02-14-2012 09:16 AM in reply to: klnkai
    In both MES and LSS, "compatible mode" is provided to avoid shear locking in solid elements, such as tet and brick.
    The selective reduced integration in MES is usually for relaxing volume locking.
    All these are about solid elements.
    For shell/plate elements, people are talking about locking, too. But locking in shell is about simulating thin shell with thick-shell formulations. Reduced integration method was an effective way before new techs get introduced into FEA.
    07-09-2012 01:40 PM in reply to: S.LI
    I came across this statement while looking up information concerning formulations of the solid elements.  Would you please elaborate on the statement "compatible modes are provided to avoid shear locking"?
    Also, is the selective reduced integration used only for eight node bricks, or is it also being used in 20 node bricks?  How about degenerated elements obtained by collapsing bricks (wedges, or tetrahedra): is the selective reduced integration still in effect?
    Petr
