• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    New Member
    Accepted Solution
    Impact Simulation on a Aluminum wheel.
    446 Views, 3 Replies
    02-10-2013 08:56 PM
    I would like to simulate an impact test that's performed on aluminum wheels for an automobile as part of the evaluation for performance.
    The wheel is tilted 13deg from a horizontal plane and mass of, let's say 1250 lb is dropped from a height of 9 inch. Please image attached.
    Please use plain text.
    Employee
    zhuangs
    Re: Impact Simulation on a Aluminum wheel.
    02-14-2013 07:18 AM in reply to: tcarrillo12
    You can use MES contact to simulate this impact problem.
    -Shoubing
    Employee
    Sualp.Ozel
    02-15-2013 06:28 AM in reply to: zhuangs
    Take a look at the following web page link to see typical results you can get using Autodesk Simulation Mechanical when performing such analysis with "MES"
    Impact Simulation on a Wheel
    -Sualp
    New Member
    03-30-2013 10:18 PM in reply to: Sualp.Ozel
    It would be just AMAZING if you can upload a tutorial on how to do that... (I mean the simulation showed in the link you provided  http://www.applycon.com/Examples/06_Wheel_Deformation6.htm    )
