• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation Mechanical and Multiphysics
    Member
    I found a bug when you run a Single Analysis with Multiple Load Cases
    110 Views, 3 Replies
    11-08-2012 12:00 AM
     I found a bug for Autodesk simulation multiphsics2013.
     When you used a Single Analysis with Multiple Load Cases, you will found the results were wrong from load case2 to the end.
     Did anyone meet this problem?
    Please use plain text.
    Member
    But the load case1 were reasonable.
    11-08-2012 12:32 AM in reply to: jiaming0503
    And the analysis results haven't this problem when used previous versions.
    Distinguished Contributor
    Re: But the load case1 were reasonable.
    11-08-2012 07:03 AM in reply to: jiaming0503
    Hi everyone,
    That bug was fixed in 2013 Service Pack 1 (SP1). The current version is service pack 2. So please update your software to the current version.
    If I remember correctly, the multiple load case bug depended on the size of the model, so the results were not always incorrect.
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    15 years experience with Simulation Mechanical
    Member
    11-08-2012 07:10 PM in reply to: AstroJohnPE
    Thanks for your help!
