• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    Accepted Solution
    CANNOT REGISTER ALGOR PRO 2010
    617 Views, 7 Replies
    10-09-2009 01:47 PM
    A messagge appears after double click on Algor:
    "Autodesk Algor Simulation is not registered correctly. Please use the Add /Remove Programs option in the Control panel to repair the installation"
    Use CCleaner to repair the register.
    Repair the installation.
    And the message still prompted.
    Any one know this?
    Please use plain text.
    Member
    Re: CANNOT REGISTER ALGOR PRO 2010
    11-12-2009 11:57 AM in reply to: lopexergy
    I would try applying the Results Environment initialization hotfix (http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14143844&linkID=13806470). Once this is installed, you'll need to re-register everything by running the RegAll.bat file in the program installation folder. Make sure you are logged in as an administrator before running the RegAll script.
    Joe Scherer
    Software Engineer
    Engineering Design and Simulation
    Manufacturing Industry Group
    Employee
    11-21-2009 02:58 PM in reply to: lopexergy
    lopexergy,
    Were you able to get your Autodesk Algor Simulation software installed and working properly?
    -Bob
    Product Marketing Manager,
    Autodesk Algor Simulation and Autodesk Moldflow
    Product and Industry Marketing
    Worldwide Marketing
    Autodesk, Inc.
    Member
    11-23-2009 03:48 AM in reply to: lopexergy
    Bob,
    I am having the same problem as described above, raised as a result of a side by side installation (v23.1 was installed at the time I installed 2010). I have tried uninstalling v23.1 and reinstalling 2010 so as to make sure there would not be issues on that respect, as well as cleaning the registry, but it is a no go. The existing hotfixes do not help, on my particular case. Regall.bat fails to register most components so that is not a valid solution or workaround, either. I have followed the manual and made sure I was running the installation and assorted procedures with elevated user priviledges.
    I have been tempted to just skip upgrading to 2010 at all, and discussed this matter at the other official discussion group, but the only valid solution appears to be to reach support. Do you reckon I should follow that road? Would there be any recommended procedures to manually clean the registry or program folders so as to start a fresh installation?
    Thanks.
    Employee
    11-23-2009 06:24 AM in reply to: lopexergy
    mamorim,
    If the instructions related to installation and registration coupled with the available hotfixes have not resolved your issue, then I would certainly reach out to the direct support team. They are equipped to assist, even connecting to your computer remotely if needed.
    -Bob
    Worldwide Marketing
    Autodesk, Inc.
    Member
    11-23-2009 09:22 AM in reply to: lopexergy
    Thanks, will proceed as suggested.
    12-23-2009 03:12 AM in reply to: lopexergy
    Thanks to you for answer my thread.
    I have tried to install that hotfix, and then use the Regall, as an administrator user.
    Look the messagge that appears attached.
    I don't know if there a problem with this windows.
    I am using win vista 64 bits at spanish.
    Firma con problemas:
    Nombre del evento de problema: APPCRASH
    Nombre de la aplicación: AlgFrame.exe
    Versión de la aplicación: 2010.0.0.341
    Marca de tiempo de la aplicación: 4a932d20
    Nombre del módulo con errores: ntdll.dll
    Versión del módulo con errores: 6.0.6002.18005
    Marca de tiempo del módulo con errores: 49e0421d
    Código de excepción: c0000005
    Desplazamiento de excepción: 00000000000b8fb8
    Versión del sistema operativo: 6.0.6002.2.2.0.256.4
    Id. de configuración regional: 9226
    Información adicional 1: fa3e
    Información adicional 2: ac0507478d1c5bd693cfc4fe3987e900
    Información adicional 3: fa3e
    Información adicional 4: ac0507478d1c5bd693cfc4fe3987e900
    Lea nuestra declaración de privacidad:
    http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0c0a
    Member
    01-04-2010 12:22 PM in reply to: lopexergy
    The problem appears to be that the regall.bat is not being run with administrator rights. In your picture, the command prompt window in the upper left shows a list of access denied errors. I would suggest re-running the regall script from a command prompt launched as an administrator (Start --> All Programs --> Accessories --> right click on Command Prompt --> select "Run as administrator"). Your command prompt window should display "Administrator: Command Prompt" in the title bar. Re-run regall.bat from this window.
    Joe
