• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    Distinguished Contributor
    madg1
    Buckling analysis not solving
    155 Views, 1 Replies
    02-25-2013 07:39 AM
    Can anyone  pointme right direction looking at the following file?thanks in advance
    Autodesk (R) Simulation Critical Buckling Load
    Version 2012.01.00.0017-W64/X64 15-Jun-2011
    Copyright (c) 2011, Autodesk, Inc. All rights reserved.
    **** Model Unit System Settings:
    Unit System : English (in)
    Force : lbf
    Length : in
    Time : s
    Temperature (Absolute) : deg F (R)
    Thermal Energy : in*lbf
    Voltage : V
    Current : A
    Electrical Resistance : ohm
    Mass : lbf*s^2/in
    DATE: FEBRUARY 25, 2013
    TIME: 09:24 AM
    Structural
    1**** CONTROL INFORMATION
    number of node points (NUMNP) = 122631
    number of element types (NELTYP) = 9
    number of load cases (LL) = 1
    number of frequencies (NF) = 1
    geometric stiffness flag (GEOSTF) = 1
    analysis type code (NDYN) = 6
    solution mode (MODEX) = 0
    equations per block (KEQB) = 0
    bandwidth minimization flag (MINBND) = 0
    gravitational constant (GRAV) = 3.8640E+02
    **** PRINT OF NODAL DATA SUPPRESSED
    **** PRINT OF EQUATION NUMBERS SUPPRESSED
    **** PRINT OF TYPE-6 ELEMENT DATA SUPPRESSED
    **** EQUATION PARAMETERS
    total number of equations = 713775
    bandwidth = 0
    number of equations in a block = 713775
    number of blocks = 1
    **** Hard disk file size information for processor:
    Available hard disk space on C drive = 117125.781 megabytes
    1**** NODAL LOADS (STATIC) OR MASSES (DYNAMIC)
    NODE LOAD X-AXIS Y-AXIS Z-AXIS X-AXIS Y-AXIS Z-AXIS
    NUMBER CASE FORCE FORCE FORCE MOMENT MOMENT MOMENT
    15993 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    15994 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    15996 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    15997 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    15998 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    15999 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16114 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16115 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16116 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16117 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16118 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16119 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16120 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16121 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16122 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16123 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16124 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16125 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16126 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16127 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16672 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16673 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16674 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16675 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16676 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16677 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    16678 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    17082 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    17083 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    17084 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    17085 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    17086 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    17087 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    17088 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    84856 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    84859 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    84870 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    84873 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85311 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85312 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85313 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85314 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85315 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85316 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85317 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85760 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85761 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85762 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85763 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85764 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85765 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    85766 1 0.000E+00 3.846E+02 0.000E+00 0.000E+00 0.000E+00 0.000E+00
    1**** ELEMENT LOAD MULTIPLIERS
    load case case A case B case C case D case E
    1 2.000E+00 2.000E+00 2.000E+00 0.000E+00
    **** Equation parameters
    Number of equations =
    Symbolic assembling using the Row-Hits matrix profile ...
    Assembled in one block.
    Real assembling in one block...
    BCSLIB-EXT solver memory status:
    in-core memory requirement (MB) = 2604.88
    minimum memory requirement (MB) = 316.56
    user specified memory (MB) = 3717.03
    available physical memory (MB) = 3717.03
    available virtual memory (MB) = 4391.56
    memory currently allocated (MB) = 2604.88
    no. modes requested = 5
    lower cutoff = -1.0000D-01
    upper cutoff = 1.0000D+04
    tolerance = 1.0000D-14
    **** Invoking BCSLIB-EXT eigenvalue solver ...
    in-core memory requirement (MB) = 3580.73
    minimum memory requirement (MB) = 1046.44
    user specified memory (MB) = 3026.54
    available physical memory (MB) = 3026.54
    available virtual memory (MB) = 3702.74
    memory currently allocated (MB) = 3026.54
    madg1
    ASIMM 2012
    Please use plain text.
    Re: Buckling analysis not solving
    02-25-2013 10:04 AM in reply to: madg1
    Hi madg1,
    That text is from the log/statistics file or summary file. They are located in a folder under "my model name.ds_data\design scenario number" and are named DS.LG6 and DS.L6, respectively. They can be opened with Notepad or a word processor.
    So if your model name were "Buckle 1.fem" and this analysis is in design scenario 3, you would want to look for these files:
    "buckle 1.ds_data\3\DS.LG6"
    "buckle 1.ds_data\3\DS.L6"
    FYI. If you search the Help for the words "File Extensions", you will locate the page that explains the directory structure and lists all of the extensions.
    Good luck. I hope you find what you are looking for.
    John Holtz, PE
    Mechanical Engineer
    Pittsburgh, PA
    15 years experience with Simulation Mechanical
