• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation Mechanical and Multiphysics
    Dan.M
    Algor vs cf design
    685 Views, 2 Replies
    04-29-2010 05:45 AM
    Hello guys ,
    I dont know if this the right place but I would like to know wich program is better in electronic system analysis.
    Thanks ,
    Dan
    Please use plain text.
    Employee
    Joey.X
    Re: Algor vs. cf design
    06-14-2010 11:48 AM in reply to: Dan.M
    ALGOR CFD:
    Flexibility for importing CAD model and handmade structure mesh, apply BC either on surface or node; Fan models with fan curve, fluid reaction force output for structure analysis, flow rate check for mass conservation verification.
    CFDesign:
    Does not support manual structure modeling, no loads on nodes,  faster fluid /thermal coupling, more turbulence models
    Jianhui Xie, Ph.D
    Principal Engineer
    MFG-Digital Simulation
    Dan.M
    06-14-2010 01:13 PM in reply to: Joey.X
    OK, Thanks
    Dan
