Autodesk Simulation Mechanical and Multiphysics
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Add preload to full bolt model?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
In reading through the help section I see the option mentioned to, Model the fastener with brick elements. Basically import a model of the bolt, most likely simplified, and use it. I've done this in Ansys Workbench and applied preload to the bolt model. Is that possible in Simulation 2012? I know we can apply preload to a beam element representation of a bolt, but I wanted to do it to a simplified bolt model.
If it can't be done directly are there any recommendations of how to fake a preload on a bolt model, like with thermal loads or a separate external load?
Thanks for the help.
Re: Add preload to full bolt model?
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Hi ladrj,
I suggest to not model and import the bolts, just use the bolted connection generator (see help files or web wiki for more inofrmation) inside the Simulation software.
Cheers
Matthias
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
This is the WIKI page talking about bolt/fasteners/beam pre-load etc., even a little bit modifying bolts in CAD models.
If this response answers your concern, please mark it as "solved".
