• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    New Member
    simulation cfd add in does not work with the Design Suite 2013
    235 Views, 1 Replies
    08-06-2012 12:41 AM
    I installed 2013 Design Suite wich consists of the all in 1 Revit arch, MEP and structural. I also downloaded simulation cfd 2013. No add in is enabled for the Revit design suite. The file is missing from the CFD installation folder and when I run the CFD config file, revit and MEP checkbox is grayed out.
    Any solutuions for transfering my revit files to CFD. The new design suite has many flaws when it comes to add ins.
    Please use plain text.
    Product Support
    royce.abel
    Re: simulation cfd add in does not work with the Design Suite 2013
    08-31-2012 07:37 AM in reply to: cmclean
    There is a solution!
    http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=19973972&linkID=18154757
    Please let use know if it doesn't work for you.
    -Royce
