• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Active Member
    problem with CAD geometry motion
    52 Views, 1 Replies
    12-05-2012 08:14 AM
    Hi Guys,
    i am having a problem with simulating the compression in engine cylinder....
    I am simulating  a motion of piston inside the cylinder chamber both having same diameter...
    I created the CFD volume on the top of piston...
    As the piston is moving up, the piston is also creating the CFD volume behind it which is not there in first place and the fluid inside the cylinder is not compressed...
    Thanking you,
    Shoeb.
    Please use plain text.
    Product Support
    wildej
    Re: problem with CAD geometry motion
    12-05-2012 11:15 AM in reply to: sshoeb42
    Best bet is to move the piston out of the cylinder in CAD, then offset it back into the cylinder within CFD using the Initial Position in motion. This way you will have a complete fluid.
    Bear in mind though that we cannot accurately model the thermal side of the solution within a sealed chamber, depends what you are looking to analyse.
    Jon Wilde
    Product Support Specialist
    Autodesk, Inc.
