Autodesk Simulation CFD
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Printer Friendly Page
problem with CAD geometry motion
- Highlight
- Email to a Friend
Hi Guys,
i am having a problem with simulating the compression in engine cylinder....
I am simulating a motion of piston inside the cylinder chamber both having same diameter...
I created the CFD volume on the top of piston...
As the piston is moving up, the piston is also creating the CFD volume behind it which is not there in first place and the fluid inside the cylinder is not compressed...
Thanking you,
Shoeb.
Re: problem with CAD geometry motion
- Highlight
- Email to a Friend
Best bet is to move the piston out of the cylinder in CAD, then offset it back into the cylinder within CFD using the Initial Position in motion. This way you will have a complete fluid.
Bear in mind though that we cannot accurately model the thermal side of the solution within a sealed chamber, depends what you are looking to analyse.
Jon Wilde
Product Support Specialist
Autodesk, Inc.
