• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation CFD
    Active Member
    labyrinth packing
    113 Views, 4 Replies
    10-16-2012 02:48 AM
    labyrinth packing
    At the entrance of 1000 Pa. medium air
    The rotation of the shaft 10 000 rev / min.
    The clearance between the shaft and the labyrinth 0.15 mm
    Determine the leakage of air through the maze.
    Placed at the output of 0 Pa.
    In solving are too little speed honey shaft and labyrinth.
    Help
    Please use plain text.
    Active Member
    Re: labyrinth packing
    10-16-2012 02:54 AM in reply to: viktooor
    Product Support
    wildej
    10-16-2012 04:52 AM in reply to: viktooor
    Please could you be a little more specific about the problem? I understand that you have 1000pa on one side and 0 on the other, the unit is rotating and you have a small clearance.
    Do you have a very good mesh through that small gap?
    What do you mean by 'In solving are too little speed honey shaft and labyrinth' ?
    Jon Wilde
    Product Support Specialist
    Active Member
    10-16-2012 06:54 AM in reply to: viktooor
    The situation is this.
    For large shaft speed of the maze thrown oil.
    Necessary to analyze and optimize the design of seals labirintnogno
    Product Support
    wildej
    10-16-2012 07:00 AM in reply to: viktooor
    OK, those help. What about the mesh on the cut-plane? You need a good 4-5 elements though each of those gaps ideally.
    What is your actual question, are the results not what you are expecting to see?
    Jon Wilde
