• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Member
    how to use rotating region in autodesk simulation cfd 2013
    91 Views, 3 Replies
    01-30-2013 05:34 AM
    Anybody tell how to use rotating region in autodesk simulation cfd 2013
    Please use plain text.
    Valued Contributor
    Re: how to use rotating region in autodesk simulation cfd 2013
    01-30-2013 09:35 PM in reply to: vijay2007galaph
    To start off, you have to build your rotating region from your CAD modeller. The rotating region is basically a volume that envelopes your rotating solid part. The rotating region is set in the materials setup and the rotating velocity or torque is set in the material properties itself. A fluid part which contacts the rotating region must be set first before you can apply the rotating region. That fluid material will be the fluid for the rotating region.
    Even more information can be found in the wikihelp section here:
    http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0138-The_Proc138/0230-Setup_Ta230/0236-Mat...
    Some very useful tips here:
    http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0407-Learning407/0726-Guidelin726/0765-Rot...
    Example model here:
    http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0407-Learning407/0408-Example_408/0590-Cen...
    Regards
    Ilyas
    Member
    02-01-2013 02:15 AM in reply to: ilyas
    Thank You Very Much My Friend
     another one doubt how to find lift and drag in autodesk simulation CFD 2013 software please help me
    Distinguished Contributor
    02-01-2013 04:28 AM in reply to: vijay2007galaph
    Try wall calculator. You need to enable the Wall forces in the Sovle solution box under Result quantities.
    I think these are pretty basic questions. Wouldn't hurt to go through wikihelp documentation, tutorials.
    OJ
