• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Accepted Solution
    cfd 2013 crashes on startup
    916 Views, 9 Replies
    06-21-2012 09:17 AM
    We are running cfd 2013 on 4 computers.  One is having a problem. On startup after the splash screen I get the following message "autodesk simulations cfd 2013 has stopped working".  I have uninstalled and reinstalled the software.  Still get the same error.  Is there a log I need to look at or system processes I need to check.
    win 7 x64
    Thanks for the help
    Brian Brisbin
    National K Works Inc.
    Please use plain text.
    Re: cfd 2013 crashes on startup
    06-22-2012 06:17 AM in reply to: brian
    We solved it.  It turns out to be a know issue.  "tabletinputservices"
    Thanks.
    Brian
    Product Support
    royce.abel
    07-19-2012 09:23 AM in reply to: brian
    For more information regarding this issue:
    http://upandready.typepad.com/up_and_ready/2012/06/autodesk-simulation-cfd-2013-crashes-at-startup.h...
    Also make sure that 'TabletInputService' or 'Tablet PC Input Service' is disabled in your services list in Windows.
    -Royce
    New Member
    07-31-2012 03:05 AM in reply to: royce.abel
    I have got a problem with Autodesk SImulation CFD - I have installed it. When I firstly run the program, it requested code and serial, which I have inserted. Then an error appeared - The program stopped working. I have Windows 7 (64bit).
    I  dont have on-screen keyboard. Service 'TabletInputService' is stopped.
    Do you know what should fix this?
    Thank you!
    08-24-2012 04:16 AM in reply to: m.habr
    I have also disabled TableInputServices from Services List but the problem of startup remains?
    What is the solution?
    Thanks!
    Product Support
    royce.abel
    08-31-2012 08:11 AM in reply to: ghmail16
    09-01-2012 02:48 AM in reply to: brian
    Unfortunately I still have the same problem. I attach a picture to show you what is the message that I get when I try to open it. It is not the same that shows in the page that you cite me.
    Thanks Again.
    Best Regards!
    New Member
    10-05-2012 01:30 PM in reply to: ghmail16
    What about those of us that need to have the Tablet PC Input Service running?
    I have a touch-screen computer that I use for design, and enabling/disabling the Tablet service every time I need to run the simulation is going to get very old, very fast.
    Product Support
    royce.abel
    10-05-2012 02:58 PM in reply to: Zh4x0r
    Please checkout SP1.  That should fix the issue.
    Thanks!
    Royce
    10-06-2012 01:50 AM in reply to: royce.abel
    My issue was that I was not opening the programm as administrator. When I run it as administrator it opened normally. :-)
