• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation CFD
    VD1
    Active Member
    VD1
    Accepted Solution
    Two questions
    193 Views, 1 Replies
    06-26-2012 11:44 AM
    I have two questions, unrelated to each other.
    1. Is it possible to perform 1 way or 2 way FSI simulation using Autodesk Simulation CFD? If yes, then is Autodesk Simulation (Algor) used for structural analysis? How the pressure/Temperature data mapped to Algor? Using files export/import?
    2. I am interested in using Autodesk Simulation CFD for ventilation analysis. Which thermal comfort modeling techniques are available to find out room ventilation effectiveness?
    VD1
    Please use plain text.
    Product Support
    royce.abel
    Re: Two questions
    07-02-2012 02:33 PM in reply to: VD1
    Hi VD1,
    The answer to both your questions are covered within the help system here: http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0138-The_Proc138/0384-Results_384/0398-Tra...
    Currently, Simulation Mechanical/Multiphysics is not support for FSI.
    For your second question I am going to point you in this direction :http://wikihelp.autodesk.com/Simulation_CFD/enu/2013/Help/0407-Learning407/0726-Guidelin726/0767-The...
    Let me know if you have any follow up questions!
    -Royce
