• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Autodesk Simulation CFD
    Distinguished Contributor
    jrm_1971
    Accepted Solution
    Turbulence settings
    98 Views, 1 Replies
    10-22-2012 06:31 AM
    With Autodesk SIM Pro (multiphysics) the "easy" turbulence model is LES (large eddy simulation). What is the equivalent in CFD 360 that makes convergence easier and less computational expensive? I am not seeing that as an option.
    Please use plain text.
    Product Support
    wildej
    Re: !!! turbulence settings !!!
    10-23-2012 02:24 AM in reply to: jrm_1971
    Hi jrm,
    Best to leave the defaults on, rather than make changes to turbulence settings, there are not really any shortcuts here. We change them depending on the model type that is being solved, to improve accuracy. Convergence should not usually be a challenge with the correct settings.
    Jon Wilde
    Product Support Specialist
    Autodesk, Inc.
