Autodesk Simulation CFD
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
Thermostat controlled fans
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
There's currently the ability to enable/disable fans based on a temperature reading. Would it be possible to impliment further control? Ideally, a fan curve could be specified with the RPM thermostat controlled, or a volume flow rate boundary condition could vary with temperature. Essentially, the same thermostat options for heat output boundary conditions, but applied to flow rate BCs or fans.
Does anyone know any way of modelling such behaviour currently?
Re: Thermostat controlled fans
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
So far I think there is no possibility to model exactly what you describe. Maybe it helps to find a solution if you describe what your goal is. One question I have is: if you specify a temperature dependent flow rate boundardy condition, you must also define (know) a temperature for this boundary, since this cannot be part of the solution. So why not specify the flow rate directly?
Or is your question only meant for internal fans?
Marco Müller
Product Support Specialist
Digital Simulation
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
Thanks marco,
It's specifically for internal fans.
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
