• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Active Contributor
    tim.sefton
    Steady State Fluid Analysis - Fan Surface
    197 Views, 4 Replies
    11-05-2011 10:03 PM
    For a interior fluid flow analsyis  does the fan surface also need to be a Inlet/Outlet surface and be eliminated from boundary conditions ?
    Tim
    Please use plain text.
    Employee
    derrek.cooper
    Re: Steady State Fluid Analysis - Fan Surface
    11-06-2011 05:22 AM in reply to: tim.sefton
    Internal fas are defined by material, not BC. The flow rate or fan curve is defined on the matrial property
    Active Contributor
    tim.sefton
    11-06-2011 06:11 AM in reply to: derrek.cooper
    For an external intake fan - does that surface need to be defined as an inlet/outlet in addition to the fan defination.
    Product Support
    royce.abel
    11-06-2011 07:12 AM in reply to: tim.sefton
    You just define with the external fan bc. No pressure needed.
    Employee
    derrek.cooper
    11-06-2011 09:49 AM in reply to: royce.abel
    yes.. but, may be obvious (or not), you should have other "outlets" defined via PRES = 0 so that air is either exhausted or sucked in from external fan
