Sim CFD 2013 SP1 Available!
Royce_adsk
Community Manager Community Manager
Message 1 of 22
Royce_adsk
CFD Users:
SP1 is now Available. Please reference this article for more information. Take note that the download in Subscription center does not say SP1, but it is SP1.
Uninstall the previous install of 2013 before you install 2013 SP1.
Royce
Royce.Abel
Technical Support Manager
Replies (21)
Message 2 of 22
Hello!
If i haven't subscription, can i download this SP1?
Message 3 of 22
brian.cranston
As of this posting, the ADLM still downloads the original release.  The browser download gets you the updated version.
-Brian Cranston
Message 4 of 22
Royce_adsk
Brian,
Could you provide more information regaring what is not downloading correctly?  Your comment about ADLM (AutoDesk License Manager) is confusing unless you are refering to something else like the 'Download Now' option.
Is there a specific product listing that isn't working like Autodesk Simulation CFD Design Study Environment vs. CFD Motion vs. something else?
Royce
Royce.Abel
Message 5 of 22
brian.cranston
Sorry, I mean the "Autodesk Download Manager" still downloads the initial 2013 release. I did it twice just to make sure I didn't mix something up.  The end result is you get the same 20120223 build, not the 20120824 build when you use the browser download.
Message 6 of 22
hartogj
Hi Brian
Thanks for the post. We have confirmed that the "Download Now" option results in download of the initial release of Simulation CFD 2013 (ie. build 20120223) and are working on correcting it.
In the meantime, Simulation CFD 2013 SP1 (build 20120824) can be accessed using the "Browser Download" option as you noted.
Thanks again for letting us know.
Jon
Jon den Hartog
Product Manager
Message 7 of 22
Royce_adsk
The pages in subscription center have been updated.
Thanks again Brian.
Royce.Abel
Message 8 of 22
DarrenP
my download seems to only download cfd design study and not cfd motion
DarrenP
Message 9 of 22
DarrenP
its not grabbing a motion license
its erroring out with a -5 error which is no such feature exists
DarrenP
Message 10 of 22
DarrenP
its also offering a standalone installation option which i thought simulation cfd was only offered as a network license
DarrenP
Message 11 of 22
apolo_vanderberg
Autodesk Support
Autodesk Support
Darren,
  You only need to download 1.
All of the downloads are to the same installation media. For Simulation CFD, there is only 1 media (32bit and 64bit) for all components. The rest is driven off the license generated by the serial numbers you have.
Message 12 of 22
DarrenP
its showing up as simulation CFD Design study
see screen shot when i switch it to standalone
DarrenP
Message 13 of 22
DarrenP
i know that I put in 811E1 as the product key
DarrenP
Message 14 of 22
apolo_vanderberg
Autodesk Support
Autodesk Support
The bulk majority of our customers do not have a "Standalone" version. You should be set to Network version where you are pointing to your license server.
We do have a Knowledge Base article about switching between Standalone and Network in the even you accidentally went down that path
Message 15 of 22
DarrenP
yes i know
i am just showing you how the program is seeing it as cfd design study and not cfd motion
DarrenP
Message 16 of 22
apolo_vanderberg
Autodesk Support
Autodesk Support
Darren,
 Correct, our Interface is the Design Study Environment.
The solver is installed automatically with the installation media. If your license file has a CFD Motion increment than you will have access to the Motion solver. If you just have SImulation CFD (the base solver) you will not have access to Motion.
Message 17 of 22
DarrenP
my license file has CFD motion in it
maybe there is something wrong with the license file that i am not seeing
DarrenP
Message 18 of 22
apolo_vanderberg
Autodesk Support
Autodesk Support
Darren,
Can you elaborate? There will not be a label that says "You have Motion"
After pointing to your license server, iwhen you setup a model you will automatically grab the motion solver when a motion model is setup .
Message 19 of 22
DarrenP
i pmed you the contents of the license file
DarrenP
Message 20 of 22
DarrenP
i am regenerating the license file now
DarrenP
