• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Autodesk Simulation CFD
    Product Support
    marco.mueller
    Setting up Remote Solve/Fast Track
    453 Views, 5 Replies
    11-01-2011 03:11 AM
    KB Article For More Detail:
    The remote solve capabilities of Autodesk Simulation CFD allow users to perform the calculation of their analysis on a different computer than their own. With this remote solve option the available computation power can be optimally used.
    If there are two computers (interface computer > analysis computer) involved the following requirements are necessary:
    • Both computers have to be in the same network (WAN or LAN)
    • Both computers need the installation of the same version of Autodesk Simulation CFD
    • The interface computer needs to be configured:
    Inside the installation folder at the interface computer (i. e. C:\Program Files\Autodesk\Simulation CFD 2012\...) there is file called server.cfg. Open this file with Notepad and simply enter the name (or IP address) of the analysis computer.
    After restarting the software at the interface computer the user is able to chose the desired analysis computer:
    Additional computers can be added in new lines inside the server.cfg-file. Also the number of CPU cores to be used for the calculation can be specified (default value is the maximum available number of cores, smaller than or equal to 2^N: so 2, 4, 8, 16...). e. g. to use only 4 cores the line should look like:
    *4cores analysis-pc-name MPI4
    *8cores analysis-pc-name MPI8
    Marco Müller
    Product Support Specialist
    Digital Simulation
    Please use plain text.
    pwilkins
    Re: Setting up Fast Track
    11-02-2011 09:09 AM in reply to: marco.mueller
    In order to use this function do we have to buy 2 licenses?
    Product Support
    marco.mueller
    11-03-2011 12:40 AM in reply to: pwilkins
    No, all is possible with one license but of course just one job at the same time.
    Marco Müller
    Digital Simulation
    Product Support
    royce.abel
    11-03-2011 07:00 AM in reply to: marco.mueller
    Excellent guide Marco!
    One concern that might trip some users up is the issue of Firewalls.
    Here is a list of programs that you should add as exceptions to cover all aspects:
    cfdcalc.exe
    mesher.exe
    cfdesign.exe
    servman.exe
    cfdserv.exe
    CFdMonitor.exe
    Member
    12-06-2011 05:55 AM in reply to: marco.mueller
    Another question about the licensing in this sort of setup.  Is it licensed per interface computer, or per solver computer?
    In the dialog above, it shows several computers that could be picked as solvers.  Does that mean they had 5 licenses?  Or is it the interface computer that has the license, and it can pick any 1 solver computer?
    Or is it a different setup with a network license where just the first solver that checks it out gets the license, but all are equal candidates?
    Product Support
    marco.mueller
    12-06-2011 06:01 AM in reply to: WillieGillespie
    the license is perfectly splitted in one interface* and one solver portion (if you own 1 full license). The computer that first obtains a license (if there is one left) has is until it is released. Other computers have to wait. The is valid for the interface and solver portion, both are independent from each other.
    * the interface itself needs at least one CAD connection (exception: Inventor Fusion connection is not licensed and free)
    Marco Müller
    Digital Simulation
